Error occurred during installation of the software SPSS Statistics
Hello community,
Being a statistics student, I wanted to install SPSS to complete my thesis but when I started installing SPSS 17.0, I was met with an error on my screen.
The screenshot of the error is as follows:
Error 1935. An error occured during the installation of assembly component
The error message says:
SPSS Statistics 17.0 Installer Information
Error 1935.An error occurred during the installation of assembly component
{9BAE13A2-E7AF-D6C3-A01F-C8B389A1E18E}. HRESULT:
0x800736CC
Can anyone please tell me what does this error mean?
I don’t know what is happening and what is the root cause behind the error.
Your comments and suggestions are most welcome.
Please help me as soon as you can as I have to complete my thesis.
Thanks a lot.
Regards.
Best Answer by Vaishnav Simmons
Answered By 5 points N/A #154422
Hi Gyle,
Try to follow these steps, maybe it could help you.
So, to resolve your problem, fix Microsoft .Net Framework 2.0 installation. Click the Start, the Control Panel and go to uninstall a program under program. Click the Microsoft .Net Framework 2.0 in the list and click the repair at the top. Next, Download and install .Net Framework version 2.0 (http://www.microsoft.com/en-us/download/details.aspx?id=1639). Reinstall the Microsoft .Net Framework 1.1.
Hope it will help you a lot.
Answered By 0 points N/A #154423
You can try the following method to see if this resolves the problem you are encountering.
Install Microsoft Visual C++ 2005 Service Pack 1 (SP1) Redistributable Package (x86) on your system. You can visit Microsoft Download Center for the download.
Installing this application can resolve your problem, it did for me. I hope this information was useful.
Answered By 0 points N/A #154424
Hello Gyle,
Usually the causes of this issue is HRESULT-2147319761. The function is not defined in DLL. Side by side these solution I have found a Techyv post "An error occurred during the installation of assembly component" where has a new technique to solve this issue. Go this Techyv page and get more idea.
Answered By 5 points N/A #154425
This problem means the function isn’t defined in .dll, error is by a mismatch of the version of mscoree.dll and version require by product being installed. Have many way to solve this issue. Here provided all solutions are good, but my recommendation visit this " An error occurred during the installation of assembly component" Techyv post to get more new information about this issue.
Answered By 0 points N/A #154426
Hi Gyle Kugler
You can apply another technique to resolve this problem. Go this Techyv post and get that one.
