Hi-ya,
I am working in Teamwork using hotlinks for quite long time. But some time very rarely I am seeing this error on and off, after a while it work fine again. The connection with the server is perfect; I don’t see any other error. What might be the root cause for this error? Please suggest me some ideas to get rid of this error before any damage. Thanks in advance.
Error occurred during the last Teamwork operation!
Server returns error code!
When using the application called Teamwork, you need to install the latest version of JRE or Java Runtime Environment. You can download the latest version from Java SE Runtime Environment. Once installed, start Teamwork again and see if the previous error can be reproduced. In case it still doesn’t, you are probably using an older version of Teamwork.
Uninstall your present version and try downloading the latest version from Download Teamwork 5. Once downloaded, install it on your computer and see if you can run it. If you still encounter a problem running it, try updating your operating system. Click on the Apple menu and select Software Update.
On the next screen, install all available updates and restart your computer to finish the update. See if this fixes the problem.
