judithmads
980 points
Posted on - 06/26/2011
Just this morning, when I am about to print some data from our database, an error message appeared.
It said printing error.
Printing Error
An error occurred during this operation.
As I check on the error, it's not pointing to the database, but purely on the printing aspects. So I checked the printer if its working. It Is connected to the print server and have enough inks to print. IÂ also connected to the printer server since I can see the printer is online, and I have also the rights for printing. So I am now wondering, what is the reason for this error message. If somebody could share some thoughts on this error.
The only solution I found is popping protected mode off temporary when printing. In case you are not positive, click on the name at bottom of the window and zoom.
Uncheck protected mode and press ok, shut the browser down and then open it. Otherwise, all I buy from bound corporations and their input on what to try and do concerning the compatibility of some sites to print off of is revert to IE7. Well, I really tried that and reformatting with Vista Premium, the 2 do not work on behalf of me either.
Hi there,
This problems normally occurs when the User Account Control (windows 7 and xp) is enabled, which causes the RSClientPrint Active X control which handles the WM_INITIDALOG (the implementation of printing process) is displaying the printing message box incorrectly.
Several workaround are available for this problem.
Go to your internet options, and then open the internet options dialog box and click the security tab and you will see the local intranet zone and on that area, clear the "Enable Protected Mode"
That should solve your problem
