An error occurred during a vaulting operation
Asked By 55 points N/A Posted on -
Hi there,
Using Vault PRO 2014 SP1 I have this error when I want to check any random file in AutoCAD Architecture 2014. I tried everything to fix, I even uninstalled and made a new fresh install of AutoCAD 2014 and is not working. Any solution ? What could be the problem ?
Thank you !
Vault Add-in Error
An error occurred during a vaulting operation.
OK
Answered By 590495 points N/A #167766
If you were able to successfully install Autodesk Vault 2014 but you can’t use it, it is maybe because of your operating system. It seems like you are using Microsoft Windows Vista and if this is right then there is really a problem. For non-server Microsoft Windows, Autodesk Vault 2014 only supports Windows 7 [Business, Professional, Ultimate, or Enterprise] Service Pack 1 and Windows 8 [Professional or Enterprise] [for Vault Basic only].
Microsoft Windows Vista is not supported. This is maybe the reason why there is an error during the vaulting operation. If you want to use Autodesk Vault 2014 as add-in for Microsoft Office Outlook, it requires Microsoft Office Outlook 2007 Service Pack 2, or Microsoft Office Outlook 2010 Service Pack 1.
If you want to integrate Autodesk Vault 2014 with Microsoft SharePoint, you should have Microsoft SharePoint 2010 [Standard or Enterprise]. To use it as add-in for Microsoft Office for Microsoft Office Word, Microsoft Office Excel, and Microsoft Office PowerPoint, you need to have Microsoft Office 2007 Service Pack 2 or Microsoft Office 2010 Service Pack 1.
