An error occurred in my game knights and merchants leopard. When I tried to run the game it always says not responding and the window and sound ambience will crash and stop, I can’t play anymore. I really need a solution for this. I hope you can give me some way to fix this error.
Thank You.
Hello Brenda,
Have you been able to successfully play this game before? If you have then there might be a bug that might have developed in the game lately due to some action that you might have performed on the computer. You will therefore need to try reinstalling the application and see if that will resolve the issue.
Nicke
Hi there user:
Your game Knights and Merchants Leopard could be corrupted. If you still have its installer (Knights and Merchants Leopard Installer), the first option I could suggest to you is to ‘uninstall’ and to ‘reinstall’ it. However, that’s a low percentage ‘hope’ to revive your game. Anyway, there’s no harm in trying, right?
But there’s an old saying, “If there’s smoke, there’s fire!” It didn’t start right, or can’t right, something’s really wrong to the application. So the second option I can give you is to recover it. Here’s the link where you can get the recovery software. http://soft.udm4.com/downloading/knights_and_merchants_mac_os/
You can also opt to download a new Knights and Merchants Leopard game for free. http://www.29soft.com/pc_game_download/knights_and_merchants_the_peasants_rebellion/
Thanks for asking via techyv.com
Best regards,
