ERROR occurred nothing to compare!
I am having a problem while comparing two tables owned by different users on different databases on different servers when running from command prompt. The tables are different and I don’t know why is nothing to compare. Can anyone help me please to fix this ?
Thank you !
ERROR
Nothing to compare!
OK
Answered By 5 points N/A #188084
Perform system analysis of all machines within your system. Ensure that all appropriate permissions have been set for access. Ensure that all machines are communicating. Also, ensure that the software on each machine is updated and configured properly. Your problem likely stems from a breakdown or several within your system. The only way to find this “drop” is with deep system analysis. There are many tools available for this purpose and many with guided use and a GUI. Utilize a search engine to find such applications.
