An error occurred with Rumble Fighter
Today, I was trying to login but when the game started up the following error message displayed on the screen. How can I fix it? Have you any idea to resolve this issue? Any idea would be really appreciated. Thanks. I am running Windows 7 Operating System.
RumbleFighter
Hacking protection has some malfunctions. (Code=10a01)
Program will be terminated.
Answered By 0 points N/A #174750
Hi Arthur,
This issue occurs if the files on the hack shield has been changed or the modifications that usually affect the files on the server end.
The simplest solution would be to reinstall the client and the hack shield.
The steps that to be followed by you is as follows:
  • Go to My Computer
  • Click on Program Files
  • Search OGPlanet
  • Remove Hack Shield Folder
  • Double Click Rumble Fighter launcher to open
  • Hack Shield will be reinstalled.
  • Once again open Rumble Fighter and it should work as expected.
