Error occurred: Unknown! Invalid BIOS or adapter selected
Can anybody help me for this error?
I have a problem in Winflash software while flashing the bios Error occurred: Unknown! Invalid BIOS or adapter selected?
What is meant by the wrong adapter what am I doing wrong here is it something to do with memory slots etc?
Any guidance will be appreciated.
RBE
Error occurred: Unknown! Invalid BIOS or adapter selected? If this error persists, try using WinFlash itself.
Answered By 0 points N/A #139137
This error can be caused by many reasons such as a corrupted file, virus and spyware, missing file, or incomplete installation. To fix this error, first, you have to reboot your system and then reinstall the program in your computer.
You can easily copy ATWinflash.EXE file of the same operating system and paste it in your missing or corrupted file. If it is caused by a virus, you have to use a good antivirus. You can download a new version of ‘ATWinflash.EXE  windows error’ fix tool and then run a scan for performance.
After scanning, click ‘Repair error’ button to repair. After the repairs are finished, restart your PC again. You can download the tool from this link: http://www.how-to-fix-errors.com/errors/fix-ATIWinflash.EXE-error-ATIWinflash.EXE-error-fix.html This error may be caused by many causes such as corrupted file, virus and spyware, missing file, uncompleted installation. To fix this error firstly you have to reboot your system then reinstall the program of your computer.
You could easily copy ATWinflash.EXE file from the same operating system and paste to your missing or corrupted file. If it is caused by the virus you have to use a good antivirus. You can download a new version of ‘ATWinflash.EXE  windows error’ fix tool and then run to scan for performance. After scanning  a click ‘Repair error’ button to repair. After the repair has been finished to restart your PC again.
