Error occurred upgrading the machine
After upgrading my development machine (Win7 x64) and a few clients (Windows 2008R2 x64) to SP1 (x86), I started to get strange issues. Why I would get strange errors, such as â€˜The setting your entered isn’t valid for this property, orAction Failed Error Number: 2950, or Runtime Error 3270 Property not found.?
Failed Error Number 2950
Phoenix:
The expression On Change you entered as the event property setting produced the following error: The setting you entered isn’t valid for this property.
The expression may not result  in the name of a macro, the name of a user defined function, or [event Procedure].
There may have been an error evaluating the function, event,or macro.
Best Answer by Vincent Maez
Answered By 0 points N/A #171560
Try to do the following:
1. Run the program with administrator rights;
2. Uninstall and then reinstall your other programs (Windows 2008R2 x64) to SP1 (x86) and see if it works properly after;
3. If these do not work, try running on 32 bit in the meantime.
Please note that the 64 bit upgrade is limited inb the sense that it does not allow a lot of add in s unlike 32 bit. In fact, you might very well be better off with 32 bit.
Answered By 0 points N/A #171561
The most common reason for this is that you are upgrading to a 64 bit capable CPU while your computer is only on 32 bit Windows version To address this, do the following:
1. Start
2. Reboot using Windows 7 cd installer or USB flash disk
3. Select Custom option during Windows installation
