Error Occurred when Creating DVD in ShowBiz DVD 2.2.2.109
I am trying to install a trial version of ShowBiz DVD 2 and when done with the installation, I tried to update it to ShowBiz DVD 2.2.2.109. Then I started to create my DVD using it but when I clicked the “Write Disk” button, I received the message “An error occurred while rendering the motion menu."And I also got the message “Failure writing the disk" attempting to start burning my DVD. What is wrong with it? How can I sort it out?
Answered By 0 points N/A #114861
This problem can be caused due to several factor this can be the problem with your media, previously used re-writable media can cause this error. This can be also problem with your hard drive so, try it by using different manufacturers hard drive like hp. This can be also an issue with your space because DVD needs lot of space to write. If you do not have enough space you cannot write your DVD, this will always show such type of errors.
So you see whether space is present or not before writing a DVD. If there is enough space present then you should use hard drive of different manufacturer. You can solve your problem easily by doing these things.
