Error occurred when installing EWB9
I downloaded Multisim 9 successfully and when I attempted to install this it thrown an error message on the screen. This error displayed at the end of stage and showed “Unhandled Exception”. I reinstall the application but bad luck. What is the cause? How can I fix this? I extremely need your help as soon as possible. Suggest me.
Error Number: 0x80040706
Description: Object reference not set
Setup will now terminate
