Error occurred when tried to start a service on Windows XP SP3
I am currently using Windows XP SP3 and receive an error message when try to start a service.
The service suddenly stops and an error comes up.
I am unable to solve this problem and don’t know about this error.
Why did come this error?
What could be the reason? Any suggestion would be really appreciated.
Error: Starting service: 1508: oh dear
Answered By 5 points N/A #167100
Hello Bernard
This issue occurs when you try to start a service because it might be disabled or no associated devices are enabled. In order for you to solve this problem, go to Start > All Programs > Administrative Tools > Services.
Find the service that stopped or has been disabled and double click it. Go to Log On tab and check so it is not disabled for the hardware profile that you are using.
Just click Enable. At the General tab, look at Startup Type and be sure that the service is not disabled. Click Automatic for the service you want. Click Ok and every problem is gone.
I hope you will find this information useful.
Randolph
