Error occurred when viewing Prefight in Acrobat Pro
Does anyone have an idea why when viewing Prefight in Acrobat Pro had the following error of compliance “Verify compliance with PDF/A-1a”?
Hello
As the error message says that compliance issue, Hence you must look for newer version, Check the existing software is properly install on your computer, and converter files. Now i am sending you a couple of link, From where can choose the right version of the software according to your system configuration.
http://get.adobe.com/reader/otherversions/
http://download.cnet.com/Adobe-Acrobat-Reader-DC/3000-10743_4-10000062.html
Thanks
you can create compliancy report to view this document by following these steps
5.Choose the following from the save windows.
