I am trying to connect with a blog site but I am getting failed because an error occurs. It states that Blog Server Error 405.
I am in trouble. Can anybody help me to resolve this matter.
I will be thankful to you.
Error Connecting to Blog
An error occurred while attempting to connect to your blog:
Blog Server Error – Server Error 405 Occurred
XML – RPC services are disabled on this blog. An admin user can enable
them at………………………………………………………………../blog/wp-admin/
Options-writing.php
You must correct this error before proceeding.
Hello Melissa,
It’s a simple problem. Just don’t worry. Server Error 405 means the server couldn’t find any RPC services. Please follow the steps below:
Login to WordPress as an admin.
Click on the settings.
Select writing.
Select Remote publishing.
Check on ‘XML-RPC’.
I hope this will solve your problem.
Good Day.
Hello Melissa,
The blog you are trying to access is suspended by host provider or may be disabled by admin of the blog and can be visited once it's made available to visit.
This could be because there might be a virus or malware activity on the blog site or might be infiltrated by somebody else. So it is suspended.
If you are the admin, please login to WordPress and fix the problem or if it is acessed illegally please firstly change all your admin and html passwords.
For more help you can visit the WordPress website or contact your host provider.
Hope this helps you and happy blogging.
Thanks,
