I am not getting connected to the server. The following message occurs while I try to connect.
What should I do now?
I don’t know what it means?
Anybody have an idea please let me know.
Ggerror
Nie mozna ustanowic polaczenia z serwerem.
An error occurred while connecting the server
Network Connection problem generally occurs when the host can't connect to the server . This may be due to your server difficulties or the driver you used for connecting internet contains a problem . You can upgrade your driver. If you use modem for connecting to internet, then you have to check your modem driver whether it is working or not. If it is not working properly try to reinstall your program.
Thanks, have a nice time.
