bentot
Posted on - 08/04/2011
Hello! Techyv Guys,
I am posting herewith an error message screen shot which received while I was using Microsoft Excel. The task that I did was converting the MS Excel workbook into XML format.
"Windows Internet Explorer
Error occurred while converting the MS Excel workbook into XML format:
The server threw an exception. (Exception from HRESULT:0x80010105 (RPC_E_SERVERFAULT))
OK"
I am wondering what went wrong with my Microsoft Excel as I have been doing this task for many times and this is the first time I met this error message. I've been stopped from doing my work for hours now because of this reason and now I am asking for your support on this error message that I encountered.
Thanks a lot.
asimm
Hello! Bentot,
The first thing which you have to do is to check which operating system that you are using. Try to update the previous or the best thing is that uninstall it and download the new and latest version from a good source and make sure that your system supports the latest version. Other thing is that there might be some file that is corrupted or some virus is there which is resisting the running of your program. So try to scan your computer and repair the Windows and other files. Do this in normal mode or the best thing is to do it from safe mode.
Secondly there might be a problem with the file type or file format. May be the file which you are trying to open is in another version of Office and you are opening it in another version. Like Excel 2003 has file type xls and Excel 2010 has file type xlsx. So check that also.
The other thing is that you must check you’re RAM. There might be a bad sector in RAM or a bad memory leak of RAM. So try to troubleshoot it properly or examine it by yourself. And then restart your system and try again. Otherwise uninstall the MS Office and reinstall it. It will solve the problem.
Have a Good day!
