I want to install this Medmount studio in my system, I tried to install and it was smooth. After installation when I attempt to setup Medmount, the error triggered, saying setup cannot continue etc. While setting up the operating system I thought all the system components are installed. But now I think some are missing? Am I right or wrong? Do I need to install them again? Thanks for your help.
An error occurred while installing system components for Medmont Studio. Setup cannot continue until all system components have been successfully installed.
Well, Medmont cannot guarantee with the compatibility of third party devices with your chosen operating system, especially if you have windows 7 or 64 bit operating system. However, Medmont Studio and Medmont supplied drivers are now supported on 64 bit platforms .But ensure with your equipment manufacturer before purchasing this. Hope, reading this site may help you further more regarding your problem.
If you need to use and install Medmont Studio on your computer, first thing to do is check the program’s system requirements and verify that your computer meets those requirements. If you didn’t check the system requirements the time you download it, try downloading the latest instead. Go to the Medmont Studio Software Downloads page and download the latest.
The E300 model
The latest version at the moment is Medmont Studio 6. It supports Windows 7, Windows 8.1, and Windows 10 Professional edition including Windows Server 2012, Windows Server 2012 R2, and Windows Server 2016. It requires Intel Core i5 3rd generation or faster processor, 8 GB RAM, 40 GB free space, and as much as possible two USB 2.0 ports depending on the instrument.
1....
