I wanted to try the MapleStory Multiplayer role playing game and play it online but every time I get an error as shown below. Can anyone help me solve this problem?
The exception unknown software exception (0xc000000d) occurred in the application at location 0x77b60dbd.
Click OK to terminate the program
points
Error occurred while playing MapleStory Online
Hi Russel C Brannon, in this situation I would suggest you to perform the troubleshooting steps from the link
Windows Error message "Bootmgr is missing Press Ctrl+Alt+Del to restart
And then check, I am sure this will fix your issue. May be you have Windows installation disk. To perform those troubleshooting process you must have a Windows 7 installation disk. My recommendation is you to check with your PC manufacturer to get Windows installation disk & then perform those troubleshooting methods.
