I am getting problem while sending mails using Netscape. Whenever I try to send mails using Netscape an error message occurs saying “An error occurred while sending mail”. You can see the full error image below so kindly suggests me to fix this issue ASAP. I would be grateful to you. Thanks in advance.
Netscape
An error occurred while sending mail.
The mail server responded:
‘‹[email protected]›’ does not match anything.
Please check the message recipients and try again.
An error occurred while sending mail using Netscape
This error usually occurs when you have not enter the recipient email address properly . Try re typing the email address properly. Most preferably the domain name ( @home.sweet.home) must have not recognized by the email server.
Or else refresh the web page and log again and try sending again will help you.
The recipient address is wrong. Please contact the recipient through other means to get the correct address. The last four characters (home) do not match any top-level domains. Top-level domains are assigned by an international agency, “The Internet Assigned Numbers Authority (IANA)” and they have not approved any such top-level domain. The common examples of top-level domains are .net, .com, and .in
