Error Occurred while on Success Script on Zoho Embedded Form
Hello all.
I am receiving a log error message and don’t changed anything.
As long as I can tell you that it worked fine last week.
Error details:
Error occurred while on Success script.
Error occurred while inserting record (through addRecord task) info from Main
Volunteer Chores Scheduler
The following field is unique
Any advice?
Best Answer by Kirkland sargent
Answered By 0 points N/A #97184
This is a problem on the form that you're using in Zoho. If you would like to get this fixed, Here's what you need to do. Try to disable the mail notification from the application if you have sendmail command set on Success script. That should fix the problem.
Answered By 0 points N/A #97185
Just go to Application settings and Disable your Mail Notification. If the error still occurs check if the error will show up in two sites, if not disable the script debugging, If yes try to use another user account, or another browser.
If it still doesn’t work Verify Active Scripting (Open Browser>Tools>Internet Options>Security Tab>Default Level>OK) If the problem still exist, Remove all temporary Internet Files.
If these methods do not resolve the problem.
Please visit the Microsoft Website https://support.microsoft.com/contactus/
Answered By 590495 points N/A #97186
Too bad you did not mention any information regarding the affected application. It would be much helpful if you include in your post the name of the program and or its version so we can determine what maybe the cause of the problem. Since this is the case, try restarting your computer then try it again. Hope it’ll work after the next attempt.
But if not, since I have no clue about the program involved, just try reinstalling the software. Uninstall the application then check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton Utilities or Norton SystemWorks. Install the program again after this and then see if this fixes the problem.
