Error occurred while using TFS with Visual Studio 2010 Ultimate
I am currently using TFS with Visual Studio 2010 Ultimate this error keeps appearing when I try to open up my solution. And it is only on my computer that it doesn’t work. What could the problem be?
Source control – Unable to access database
The associated source control database could not be accessed.
Temporarily work offline in disconnected mode
Microsoft Visual Studio will attempt to reconnect the solution or project to
source control after closing and reopening the solution
Work offline in disconnected mode
You will need to use the Change Source Control dialog at a later time to
reconnect the solution or project to source control
Permanently remove source control association bindings
Manually change bindings and connections (advanced)
OK HELP
