An error occurred yii disable enter.
Hello guys,
An error occurred yii disable enter. What is this error all about this happens while I am entering some data or files from an Microsoft excel application. I need to get this all data done and encoded in the Microsoft excel, can you give me a solution to this problem. Thank you.
Best Answer by LyanaHay
Answered By 0 points N/A #186951
Hello John,
Have you tried to restart the microsoft excel application and see if it will work? If not, then I will highly suggest that you try that. Also ensure that you are entering the values in the table accordingly. If a field requires integer values, then mixing with other non-integer values may cause such an error.
Nicke
Answered By 0 points N/A #186952
 I think you are getting this error because of some problem like:
1] You are editing file with shared permission without having write permission for you.
2] There is not enough space in drive where this file is stored
3] The 218-character path limitation has been exceeded when you save an Excel file.
4] The Transition Formula Evaluation feature is turned on in Excel.
Solutions:
1} Try to save file again with different name on different location
2] Try to save the Excel file in Microsoft Windows Safe Mode
