Error occurs during activation of Office 2010
An error appears every time I try to activate the Office 2010, does it mean it not compatible with my OS?
It depends on the kind of error you receive when you activate your Microsoft Office 2010.
Usually, in Microsoft Office, if a package you are planning to install on your computer is not compatible with the operating system you are using, you won’t be able to install it.
You will instantly receive a message at the start of the installation saying that the software you are installing is not compatible with the operating system you are using.
In this case, you need another package that has the right version for your operating system.
But here, your problem is only with activating the program which means you have successfully installed the package on your computer.
At this stage, you are sure that the application is compatible with the operating system and the only problem left now is its activation.
Usually, you need a serial code to activate a Microsoft Office package. If you are unable to activate your package and you have your serial key with you, it is possible that it is the wrong code for your package.
Try entering it again and be sure to input the characters correctly. If it really doesn’t work, you need to obtain another serial code to be able to activate it.
