Layla M
Posted on - 10/19/2011
Hi, I’m dealing with the problem of updating to AutoCAD Architecture 2009. The previous version was working just fine but ever since I’ve tried to update I’ve had the same trouble over again. The error message which appears is this:
Error 1321. The Installer has insufficient privileges to modify this file: C:Program FilesAutoCAD Architecture 2009acgex17.dll"
If there are any ideas on this one I would appreciate it very much if you answered here.
Error opening AutoCAD Architecture 2009
If you are installing AutoCAD Architecture 2009 32-bit version on an operating system other than Windows XP, you are installing the wrong version of the application. You are using Windows 7 and it is not compatible to be installed with either the 32-bit or the 64-bit versions of the application. AutoCAD Architecture 2009 only runs on Microsoft Windows XP and Microsoft Windows Vista.
For much detailed information about AutoCAD Architecture 2009, read its system requirements below:
Windows XP Service Pack 2
Pentium 4.3 GHz, or AMD Athlon 3.0 GHz or higher processor
2 GB RAM, 3 GB is recommended
2.5 GB free hard disk space
True color video card with 1024 x 768 screen resolution
Microsoft Internet Explorer 6.0 or higher
DVD drive
AutoCAD Architecture 2009 64-bit version
Windows XP Professional 64-bit, Windows Vista 64-bit
Intel EM64T or AMD Athlon 64 processor
2 GB RAM, 4 GB is recommended
3.5 GB free hard disk space
DVD drive
You need to replace your operating system with either Windows XP Service Pack 2 for the 32-bit version of the application, or Windows XP Professional 64-bit for the 64-bit version of the application, or Windows Vista 64-bit also for the 64-bit version of AutoCAD Architecture 2009. Otherwise, install the appropriate version of the application that is compatible with your operating system.
