Hi I am installing Evaer Video Recorder for Skype, but i am failed to open it. What should i do to open the Evaer Video Recorder that i installed? here is the picture of the error.
Evaer Video recorder for Skype 1.1.1.26 Setup
Error opening file for writing:
C:Program FilesEvaervideochannel.dll
Click Abort to stop the installation,
Retry to try again, or
Ignore to skip this file.
Abort Retry Ignore
Evaer Video Recorder for Skype 1.1.1.26 Setup
Error in opening Evaer Video Recorder for Skype
Hello, and welcome to techyv
Sometimes, installing applications as Evaer Video Recorder for Skype requires
Administrator rights. In other words you must log in into windows as an administrator.
You should also check for updates for both applications Skype 1.1.1.26 and Evaer
Video Recorder. I hope it will work for you !
Hi Dixon eartha? First you have to download the latest version from this site http://www.evaer.com/download.htm then exit ever and Skype if they are running please click on windows bar to exit and kill the process. Uninstall the old version of Ever video recorder by this means: Start > All Programs > Evaer > Uninstall. Open Evaer installation directory and check if there exist any files, delete if there exist. Install the new version using the setup file to upgrade.
Hope this will help you.
