An Error opening file “test.mpo”
When I open an .mpo extension file, this error appears.
Thank you in advance for solving:
XstereO Player
Error: You need at least OS X Lion to pen MPO files.
XstereO Player
Hello Shirlyn,
You may know that .mpo files can’t run without OS X Lion or OS X 10.6 or later. So it’d be better if you install Lion or later version to run .mpo files smoothly. Just download the OS and go through the installation process. After the installation you can run the mpo files easily.
Good Luck.
Hello Shirlyn,
The error you have mentioned it means you need OS X Lion to open MPO files. You may know that MPO files cannot run without OS X Lion. So if you have the software, then try to run the file with it. Otherwise you can download the latest version of the OS x lion from the internet for free. Hope this could be a help.
Thank you.
