Error opening/ initializing the selected video out
Hi experts,
I was trying to set up my computer for video output. My operating system is Ubuntu and I don’t know how to configure it. Meanwhile the error pop-up and informed, “Error opening/ initializing the selected video_out (-vo) device.” I want a solution to outline video out on my computer. I would be grateful. The image of the error message is given below:
Fatal Error
Error opening/initializing the selected video_out (-vo) device.
OK
Thanks a lot.
Answered By 0 points N/A #106125
Hi carmen, i have read your problem about fatal error your getting with your ubuntu operating system. To configure the operating system all you  have to do is you should have more than one version of ubuntu preferably in ISo form ona a local drive. You can start with using the old version like using 7.10 with 350MB of ram and the i8042.noloop flag. Get to the install screen, follow on screen instruction up to your desired version.  After 30 minutes of trying yet you still what you want to achieve try to follow the primrose path to Suns'. VirtualBox: https://www.virtualbox.org/wiki/Downloads. In order for your to work on your Microsoft Pc, you need to make some changes manually as well. Try install Ubuntu 8.04 Desktop for Virtual PC 2007. Create a new Virtual machine, start the Live CD version of ubuntu from a cd or the ISO file in safe graphics mode. Install ubuntu onto the new virtual hard disk and reboot.
