Error opening installation log file
ERROR_INSTALL_LOG_FAILURE 1622 There was an error opening installation log file. Verify that the specified log file location exists and is writable.
I'm trying to help a friend of mine setup Walmart music downloads. When the install begins, this message pops-up and the install fails;
Windows Installer
Error opening installation log file.Verify that the specified log file location exists and is writable.
The only option in the pop-up is to click ok and the install fails. I've checked in group policies under Windows installer and logging is enabled. I've never run across this problem before and I'm not sure where to look or what to do to fix it. I'm hoping someone here has seen this before or has an idea how to resolve it.
This machine is running WinXP Pro/SP1, upgraded from Win2K. Any help would be greatly appreciated.
