Jody Akerly
80 points
Posted on - 12/11/2012
Hello People,
While opening PSD files with Photoshop on may machine running with Leopard, I received an error message. It says, "The program has encountered an error". It did not work anymore.
If you have any idea to solve the problem, please help me to solve the problem.
Thank you for the help.
Error on opening PSD Files with Adobe Photoshop on Mac Leopard
Please follow these steps to fix the issue with the Photoshop product on your computer.
>>Make sure you have installed the latest and genuine version of Photoshop.
>>Open Photoshop and immediately, hold down the Ctrl + Alt + Shift keys.
>>You will get a reset window.
>>If this does not fix the issue, try reinstalling the Photoshop product on your computer.
This should fix your issue.
Thanks and regards,
Skarbos Jay.
