Error in openVPN when trying to run as daemon service
Posted on - 05/29/2015
While trying to install Ubuntu, I had no issues. Now I have also installed openVPN for Ubuntu. I have got all the certifications from internet and also successfully prepared the client CONFIG file. But, i am facing problem when I try to open the VPN from the Ubuntu terminal. I am failing to connect to the installed openVPN server. This also happens when I try to open the openVPN as a daemon service. The client is unable to connect and services are failing to run. Where to find logs from daemon start of openVPN?
