Error of Opera mini for mobile
Hello All,
Hello All,
Downloading larger files with opera mini do create problem and sometime gives error. Ne can’t download larger files as it only allows the smaller files. Try using Opera mini 5 that allows even a larger files and one can download a complete Microsoft by using this opera.
Try this opera 5, hope this will help you in resolving your problem, but don’t forget to delete the older version first. Opera 5 can download as large as 100 MB file.
Hello Owen,
You would not be able to download any large file using Opera mini. The cause is BIS limitation. It would show you an error message and an error number too. It would be better if you tell us about the error number. Although try any other browser. Also you did not tell anything about your mobile or its operating system. So it is little hard to find the proper answer for it. But Opera mini do have some BIS limitation problem and that’s why it do not allow downloading large size data.
Thank you,
Riley Weaver.
Hello Arturo,
This error can be removed by doing the following actions:
1- Always check your mobile connection settings.
2- Change the Opera mini settings, Go to Settings -> Advanced settings -> Here change Socket to HTTP.
3- Do not remove your memory card, as it changes the saved location and file fetching error appears.
4- Clear your history, deleted some of your saved pages before saving new ones
This will help you out in your problem
Thanks
Notifications
