Error ora-06508: PL/SQL: could not find program unit being called
I have a very strange error. We have a database with multiple schemas, now in one schema a new error occurs. This is the situation:
I have a view, with a call to package 'A' which calls package 'B'.When I do a select on the view in SQL/Plus , I get error
Here all the units are valid. If I recompile the units which are called, the problem disappears but after a few hours it re-appears. We try to increase server shared memory also but that didn't help. Can any one suggest the solution for this?
Cyan.
