When you attempt to connect to a file transfer protocol server but fail having a number of causes like unestablished communication or connection, error in parameters and eventually a denied access, what solutions can be done to push through with the connection?
Error in parameters and eventually a denied access
FTP means file transfer protocol and it is a system that allows you to login to a specific server and upload or download your data or information. Â May I know what FTP server you are using?
Basic procedures you may need to do if you are unable to connect to the FTP server are as below:
·        Make sure that you have entered the FTP server name correctly. An additional character may result for users not being able to access the server.
·        Make sure you are typing in the correct authentication information
Usually, there would be text flashing through top of the screen when you connect to the site with the error.
