Hi Experts,
I have install the PDF reader and when I open PDF file, it shows the error "PDF Optimizer menu missing". Please send me the appropriate link for downloading the pdf reader software or send me the alternate solution . Thanks!
Jamior Miston
Error Pdf optimizer menu missing
Can you tell us what Acrobat version you are using? Not all Acrobat versions have the Pdf Optimizer feature, and some versions had this feature moved to different locations from each other. An example is Acrobat 9 having it available in the Advanced menu, while Acrobat X had it moved to File > Save As > Pdf Optimizer.
Hey. Jamior Miston,
As you have stated above that you are in need of trusted sources to download PDF reader. So, here I am providing you two links to download PDF reader.
Kindly read the document before installing as this will help you to judge the product better.
Here are the links to download Adobe Link & Also you can try nitro with your existing link Have you tried a repair? :
Help > Repair Acrobat Installation.
I hope that this will fix your problem.
Thanks & Regards
Gillam Janetj
