Keny bell
Posted on - 07/19/2012
Hello techyv users, I need help on this:
I received an error message when you try to open a file type that was blocked by your registry policy settings in Word 2010, in Word 2007, or in Word 2003 In Enthusiasm Workplace Concept 2010, Enthusiasm Workplace Concept 2007 or Enthusiasm Workplace Concept 2003, I attempt to start a program that was stored in an Enthusiasm Concept structure. As I applying this the submission does not start. Furthermore, I get one of the pursuing problem information:
You are attempting to open a file type that is blocked by your registry policy setting.
Any help will greatly be appreciated.
Error in Policy Settings in MSWord, WorkPlace Concept
This problem arises because of modification of windows privacy policy. You just need to repair windows to fix up errors, explorer errors, ActiveX errors, JavaScript errors etc.
You can use variety of applications like tune up utilities, advance system care. I recommend PL Cleaner Pro.
Install that program and lunch that application.
Register it if required.
Update the windows component.
Now you have to reimage the machine.
Fix windows by windows repair toolkit.
It will repair full database by replacement.
He downloading link is given below:
http://www.pc-cleaners.com/PC_Cleaner_Pro.exe
Your problem should be fixed by now.
Thanks for having your time.
