Hi, Recently, I was just about to post on a Drupal Blog, when suddenly the attached picture that states "Problem with the Blog Server", "Server Error 1 Occurred" popped-up.
Problem with the blog server
Blog API module is not configured to support
the 1 content type, or you don't have sufficient
permissions to post this type of content.
OK
This has occurred to me in the past. What can I do to prevent this error from popping-up again? Thanks in advance.
Error popped when about to post on a Drupal Blog
I faced a similar problem in the past. When I contacted the support they gave me the following instructions:
1. The version 1 of drupal does not support the API module. This is a technical problem. So instead you could use other modules.
2. Try to use the Windows live writer module to post on the blog.
3. You could also try using the Zoundry raven module to post on the blog.
4. Find out from other users what module they are using to post on the blog. This should give you many options.
The version 2 of drupal will overcome this problem in the future.
Hope this information helps you.
