Error popping up while installing beta version of UDKInstall-2012-02
Hello all,
I am trying to install the beta version of UDKInstall-2012-02, but the following error keeps popping up.
Installation Failed
Extracting all files failed with the exception:
Ionic.Zlib.ZlibException: Bad state (invalid stored block lengths)
at Ionic.Zlib.InflateManager.Inflate(Flush Type flush)
at Ionic.Zlib.ZlibCodec.Inflate(Flush Type flush)
at Ionic.Zlib.ZlibBaseStream.Read(Byte[] buffer, Int32Â offset, Int32
count)
at Ionic.Zlib.DeflateStream.Read(Byte[] buffer, Int32 offset, Int32
count)
at Ionic.Crc.CrcCalculatorStream.Read(Byte[] buffer, Int32 offset, Int32
count)
at Ionic.Zip.ZipEntry.ExtractOne(Stream output)
at Ionic.Zip.ZipEntry.InternalExtract(String baseDir, Stream outstream,
String password)
at Ionic.Zip.ZipFile._InternalExtractAll(String path, Boolean
overrideExtractExistingProperty)
at UnSetup.Utilis.UnzipAllFiles(ZipFile Zip, String Destination)
Please visit http:\udk.comtroubleshooting for assistance.
                                          OK
The program is downloaded using IDM and has been checked using md5. I am using Administrator on windows 7 and the antivirus is disabled.
Any advice will be appreciated.
