grahamamie
20 points
Posted on - 02/17/2012
Hi, everyone!Â
I have a Microsoft Windows ME (Millennium Edition) computer. My printer is an HP Deskjet 930C and I use a Kodak Imaging software to print my .tif documents. These documents were scanned, annotated, and then supposedly printed. However, I get this message whenever I try to print them:
"Error printing to LPT1: For the printer HP Deskjet 930C Printer. There was a problem printing due to an unknown system error."
 I have already updated the printer driver from the HP website but I still get this error message. Has anyone encountered such a problem? If so, your help will be very much appreciated.
Thanks!
Error printing with HP Deskjet 930C with Kodak Imaging Software
Hi
The problem you are discussing is that your printer is not working properly so you want to work it properly and the problem with your printer is that while printing it shows an error and the error is system error and you already have update the HP driver with the latest version of the drivers but it still it doesn't work. For this you should try other software to print there is a possibility that the software you are using is not good enough or it is not compatible with the HP printer there are lots of software for printing why don't you try the other software there are lots of software for such use so you should try and replace the software you are using. So this will help you solving problem and will help you in printing in a good way there are lots of friendly user software which very easy to use and very quick so you should check this
One thing more unplug your printer and uninstall its driver and then again connect the HP printer and again install the driver it will help you solving your problem and by the way try this option first and then try the above one I have discussed and read the whole solution carefully it will help you solving your issue.
