Error Problem Arises As 0xca00a000 Error While Updating Of Windows
When the 0xca00a000 error occurs? Explain the steps to resolve the error code and the cause of this error message?
0xca00a000 error is a Windows Update error and the code states: 2018-07 Cumulative Update for Windows 10 Version 1803 for x64- based Systems (Update code) – Error 0xca00a000. Check out the following fixes for error 0xca00a000:
Method 1:
Open the WU Troubleshooter.
Step 1: Hold Windows key + Q and input ‘troubleshoot’ then select troubleshoot to open the settings app.
Step 2: Select Windows Update and press Run the troubleshooter button.
Step 3: It will find the fixes and then click on the Apply this Fix option.
Step 4: Restart the Windows and check for updates again.
Method 2:
Manually update the Windows by download the update file and install it.
