I am having this problem with MS Info path. I already checked the security tab and it didn't help.
This file is on the same computer as form where I am opening it. But it is showing the following error message.
How can I solve the problem?
Microsoft info path
This form cannot be opened because it requires the domain permission level and it currently has restricted permission.
To fix this problem, open the form from the location it was published to.
Published location:file:///c:UsesTim%20BothaDesktopListing%20-%20Residensieel.xsn
Error Problem with Microsoft Infopath
I think you need to open the file using the user account of the person who published it. The dialog box says that you need to open the file from its original location which is "file:///c:UsesTim%20BothaDesktopListing%20-%20Residensieel.xsn". If you will analyze this, the form was published using the Tim Botha user account. If you are currently logged in using a different user account on that computer, try logging in using Tim Botha’s account and then try opening the form again and see what happens.
If you still encounter other problems with Microsoft Info Path, try reinstalling the program. Uninstall Microsoft Info Path from your machine then check your computer for any possible errors. Use a disk utility application to check the system. Install Microsoft Info Path again after this and then do a test if it works.
