Hello Experts,
An error problems streaming quicktime Firefox 5. The error occurred in my Firefox 5 what shall I do to fix this kind of bug or problem I need to get this working for the next few hours and I need my browser to do some important matter for browsing. I hope you can help me to resolve this issue.
An error problems streaming quicktime firefox 5.
Hello Danield Make,
You have got some problem about Firefox. To overcome those problems you have to first uninstall your Firefox browser. After uninstall please download Firefox software from below link. To download Firefox please click below link:
https://www.mozilla.org/en-US/firefox/new/
After download Firefox install it and star your browsing gratefully.
Hi Danield Make,
It is possible that the QuickTime plug-in on your Firefox is corrupted or it might not be detected properly by the browser. This is a normal issue even when the selected media type is correct. You must reset the QuickTime browser plug-in to fix this issue. Please follow these simple steps: Make sure that your Mozilla Firefox browser is closed before doing this. Open your browser’s installation directory plug-in folder and delete all “npqtplugin*.dll” files. When done, open this directory C:Program FilesQuickTimePlugins and delete all “npqtplugin*.dll” files.
You can then reselect your media types by following this path: click Start menu-> Control Panel-> QuickTime-> Browser Tab-> MIME Settings. I hope this helps you.
