Hi Guys! I am encountering a problem about Authorware Web Player Error. Â
I am using Adobe Web Player 2007. But every time I open some an internet solution website an error appearing and says invalid version.
The error images attached here. Why it says invalid file version?
Do I need to replace it and install another one? Please help me. Â
Error reading the Author Web Player map file.
Invalid file version. File://C:test.aam
SARA U
10 points
Dear Jeffery
The Authorware Web player comes with three different versions:
1-Â Â Â Â Â Compact
2-Â Â Â Â Â Â Complete
3-Â Â Â Â Â Full.
The compact and complete versions will NOT play the contents which were packed with any other version or lower versions of player other than the current version. This can be done by the full version only.
Now check the version of player you have. The error reported is for a web piece created with a lower version of player, and you are trying to play it on either the compact or complete version.
If you want to play these pieces, uninstall this version, and install the full version of the player.
SARA
