Hello experts,
I am Saurav, from India. I am using Microsoft Windows XP service pack 2 with adobe acrobat reader software Version 5.00. When I want to start any file with Acrobat Reader I am getting this error message. “Error Reading linearized hint data”.
Error reading linearized hint data with Acrobat Reader
Dear Tricia klein,
According to the error message you receive when you try to open PDF files. If you are using a browser to go to a URL containing a PDF file you may encounter this problem. In order to resolve this issue please consider following these steps: Open Acrobat Reader, go to "Edit" and click preferences.
Select the option "Internet" from the table placed in the left. You will find a check box labeled "Allow Fast Web View", uncheck this box and then click OK to save your changes. Now try again and you will find your problem solved.
Hope this may help you.
Best of luck.
