Error Reading Registry System.Format Exception Problem
Hi I faced some problem in troubleshooting DB so I re partitioned the C drive and created a new D drive and also uninstalled HEM and related files everything and after a reboot installed a new version 6112 but the error is as same as in below figure and even I tried changing the default directory but no use of it as in pressing OK on the error message 3 times getting message and another error is that while I am trying in restoring the synchronized online database works fine for 10 min after that error is “Sync Error. Response from server does not contain valid XML “. I am not getting where the actual problem so help me in solving this trouble.
Error Reading registry Sytem.FormatException: String was not recognized as a valid Boolean.
at System.Boolean,Parse(String value)
at HoldemManager.Modules.ULTabIeScanner.Global.ReadMySetting(Stnng KeyName, Boolean def)
OK
