Error received while launching SmartSVN for the first time after installing
This is the error that I receive when I launch SmartSVN for the first time after installing – "It seems that SmartSVN is already running".
Here is the screenshot:
It seems that SmartSVN is already running.
Instead of running separate instances you can open ‘ multiple project windows in SmartSVN.
If you are sure that no SmartSVN instance is running any more you should delete the lock file /Network/Servers/olserver/UsersftomwiIson/Libra ry/Preferences/SmartSVNf_lock.
OK
If you are sure that no SmartSVN instances is running
any more you should delete the lock file.
SmartSVN has never been installed before and processes confirmed this. I also removed the lock file, but the same issue reoccurs when I run the application next. I am using a MacOS,and the download didn't seem corrupted in anyway.
I am using a network login. So, I don't know if this is important or not.
If you need any more info let me know and thanks in advance.
