Error: A red X, Invalid Drive, Error code 1327
Hi all,
I am facing a problem while trying to install software from a CD. That application was my phone software along with Activesync and I found a yellow triangle box reading, "Sonic DLA, your version of DLA can read files on this disk but you will not be able to add them. ”
Also got a red X "Warning, the local language and default (WWE) configuration XML file cannot be found or invalid; please contact the disk manufacturer. ” Finally, a yellow triangle with this message, "Microsoft Activesync Error: Invalid Drive: F: Please select a valid drive”.
Then with Turbo Tax – A, I received a message reading, “red X, Invalid Drive, Error code 1327”.
I also removed an external hard disk but had to add another one. I have also checked the disk management page and it is all the same.
Error: A red X, Invalid Drive, Error code 1327.
So please help me get rid of it.
