An error related to DOT has occurred
I am trying to use “ontoviz” tab and “OWL viz” tab but I get this following error message every time when I attempt to use these tabs. The error shows “An error related to DOT has occurred. This error was probably because OWLViz could not find the DOT application. Please ensure that the path to the DOT application is set properly”. I am looking for an expert for the resolution.
Thanks for help.
DOT Error
An error related to DOT has occurred. This error was probably because OWLViz could not find the DOT application. Please ensure that the path to the DOT application is set properly.
