Error replicating Public Folder DB from Exchange 2007 to 2010
Hello TechyV buddies!
I am having some problem with Microsoft exchange. I have searched on ways in moving or replicating folders on ms exchange 2007 to 2010. I have followed the steps given by Microsoft in replicating vs moving folders but that did not work because an error occurred. Here are the steps that Microsoft have given me: 1. Create PF DB on 2010, then 2. Via the 2010 EMC, choose a folder you want to replicate, right-click, choose replicate, set couple parameters (such as schedule), 3. Pick the 2010 destination, and click "Make the Magic Happen!"
After doing the steps the error just came out. The errors are these:
——————————————————– Microsoft Exchange Error
——————————————————– The following error(s) occurred while saving changes:
Set-PublicFolder
Failed Error:
Cannot save the object 'Admin ServicesAdmin Services Calendar'. Make sure that you specified the correct Identity and that you have the necessary permissions to save it.
MapiExceptionNotFound: Unable to set properties on an object. (hr=0x8004010f, ec=-2147221233) Diagnostic context:
Lid: 45095 EMSMDB.EcDoRpcExt2 called [length=590] Lid: 61479 EMSMDB.EcDoRpcExt2 returned [ec=0x0][length=580][latency=31] Lid: 23226 — ROP Parse Start —
Lid: 27962 ROP: ropSetProps [10]
Lid: 17082 ROP Error: 0x8004010F
Lid: 30561
Lid: 21921 StoreEc: 0x8004010F
Lid: 27962 ROP: ropExtendedError [250]
Lid: 1494 —- Remote Context Beg —-
Lid: 1238 Remote Context Overflow
Lid: 21970 StoreEc: 0x8004010F PropTag: 0x668F0040 Lid: 21970 StoreEc: 0x8004010F PropTag: 0x3D210102 Lid: 19149 Error: 0x0
Lid: 24509 Error: 0x0
Lid: 31229 Error: 0x0
Lid: 21970 StoreEc: 0x8004010F PropTag: 0x67870102 Lid: 21970 StoreEc: 0x8004010F PropTag: 0x678A0102 Lid: 21970 StoreEc: 0x8004010F PropTag: 0x67870102 Lid: 3010 StoreEc: 0x8004010F
Lid: 3650 StoreEc: 0x8004010F
(FYI, I trimmed out a few of these LID lines) Lid: 1750 —- Remote Context End —-
Lid: 26849
Lid: 21817 ROP Failure: 0x8004010F
Lid: 25761
Lid: 1940 StoreEc: 0x8004010F
Lid: 25297
Lid: 21201 StoreEc: 0x8004010F
——————————————————– OK
I have tried to solve this error but I can’t find any solution. I am also logged in as administrators so if you think the problem is about the permission then I think you are wrong. I can access the server but the error above is the only issue I am having right now. If there is anyone out there that can help me solve this problem please reach me through this site. I will really appreciate the effort in helping me solve this problem. Thank you!
