Error ripping JPG image on Roland Versa Works
I am ripping my image for sticker printing to be printed on Roland SC-545EX printer.
The ripping tool or the Roland Versa Works prompt me an error saying the JPEG is corrupted.
I deleted the image then once again convert my Photoshop image into JPG and then rip it once more.
Still, the image can’t be ripped, and it says the Image is corrupted.
What should I do now?
Answered By 0 points N/A #81525
There are some instances that when you are scanning your computer from viruses, you will be seen on the list of infected files a JPG files. And if you open the image file on a fax of the image viewer, some parts of the image are missing, this is causing by the virus that infects JPG files.
Roland Versa Works doesn’t recognized images with other codes inside with that does not belong to the image type of the file. Each type of image has its type of signature so once the image file is infected header file on the image file doesn’t recognize virus codes or damaged area by a virus.
Roland Versa Works also recognize other files than JPG format. It can also read the TIF file. TIF file when converted from Photoshop file, it saves the layers and info of the Photoshop document. This file is recognized in Roland Versa Works.
Convert your Photoshop file into TIF then Rip.
