Error running AnyDac Component, please help
I have developed an application which uses any dace component.
Operating system is Windows 7. It installs successfully on the system, but when I attempt to execute the application it prompts for some sort of ODBC error. I'm totally lost about this error and unable to resolve this issue.
song list editor
[Any DAC][Phys][ODBC][Microsoft][ODBC Microsoft Access -stuur programma]Algemene fout Kan de
registers leutel Temporary (volatile) Ace DSN for process 0xa5c Thread 0x19c DBC 0x346796c
Jet niet openen.
Can somebody help me in this regard, it will be greatly appreciated.
Thanks in advance
Jude
Answered By 590495 points N/A #142754
Since it is a newly created application, try rebooting your system and then try opening it again. If the problem has not changed, try checking your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton Utilities, PC Tools Performance Toolkit, or Norton System Works.
If the problem continues, I think the best possible solution is to check your program again since you are the one who developed it. The image of the dialog box you posted is in a different language that’s why I can’t understand the exact meaning of the message. I wish you include an English translation of the message to fully understand it.
